Hi Guys!
I am building a detached pergola. I’ve got a huge concrete slab in my backyard with no shade.
I have bolted the 6 x steel U-shaped post supports to the concrete using dynabolts. These will hold the posts.
I’ve got 6 x 90x90 posts arranged 3 a row. They span a total 8 meters. (4m span between post. And the depth of the pergola is 4.2m.
I have used 2 x 9m SMART LVL 15 H3 240x42 Structural LVL Timber pieces to span as bearers. I wanted a 45cm over hang on either side of the furtherest posts. These LVL sit on the three posts affixed with bolts and set on a lap cut into to the posts.
for the rafters I have chosen
Treated Pine H3 F7 Timber 140
X 45 - 4.8m lengths that I will space 55cm apart.
my question is are the 140 x 45 suitable to span 4.8m without twisting and warping over time? It won’t carry a heavy load. I am fixing plastic roofing on top and that is very light. I plan to use battens 70 x 35 spaced 90cm apart.
any advice?
I used the attached load sheet to confirm that the 140 x 45 H3 F7
was the suitable timber to choose but now I am not sure.
also, note that on my design drawing I had originally intended to set the rafters flush to the beam so birds couldn’t nest but now I have decided to sit them on top because I prefer the look. I have notched 6cm into the LVL per rafters for them to sit in that notch. What screw should I use to secure them to the LVL?
thank you.
