Hi all,
I'm in the process of planning some underfloor insulation for part of my house. My house is a 90's build house in Brisbane where the upstairs area hangs out over the built in downstairs by about 40sqm. This area is partially open aired, and partially built in by the laundry which is essentially the temperature as the outside given the door is always open and its not insulated itself. Unsurprisingly on a hot day, the floor is noticably warmer in this area of the house and is a huge source of heat into the house.
I plan to use earthwool underfloor insulation but I would like to know if I need any form of moisture barrier between the underside of the floor and the insulation, and do I need some other sort of barrier between the insulation and the open air.
This area is not exposed directly to the elements, but is open aired and prone to filling up with **** etc, and being Brisbane it can get humid at different parts of the year.
Thanks in advance
