I'm repairing some tiles around the pool area where the slab has crack and lifted slightly (a few mm). I've removed the tiles and ground the concrete so it's flush across the crack. (See image). Now I'm getting ready to tile, but I'm not sure of a few things.
My questions...
1. How to fill the crack in the slab? I was going to use filler rod with Maxisil Pool Silicon sealant. Is that the right method? Should I open the crack a little wider?
2. What tile adhesive offers good flex?
3. Can I lay new tiles across the crack or should I cut them to follow the crack?
4. Finally, what is recommended for the grout?
