Hi, I'm building a large, essentially L-shaped deck wrapped around our house. It starts by the sliding doors (north-west) with a very low 220mm profile, but the ground gently slopes away to the south and the east, so it will end about 600mm high. I posted last week about this on someone else's question, but I thought it was better I started my own thread.
I'm using a ledger board attached to a 3.56m west-facing concrete foundation, which will support 145x45 joists spanning 2m. So my question today (and this may not be my last!!) is about fixings. I'm looking to fit the 145x45 ledger board with four pairs of stainless steel screws (we're by the sea). I'm just wondering whether I need dynabolt-type fixings, or can use hex-head M12 masonry screws.
Also what length? Some guidance I've seen suggests the screws should be embedded 100mm into the concrete wall, which sounds a lot. By the time I've allowed for the 45mm thick ledger boards, 12mm packing and a couple of washers, that would come to a 160mm long screw, which seems excessive and perhaps hard to come by ...
Thanks in advance for any advice!!
