I would like to install two garden taps. There is 25mm poly pipe in our garden that is currently capped of with a screen valve as the old metal pipe leading to a tap had begun to leak. The taps will need to be located about 20 metres apart.
I would like to use the quarter turn taps this time but I can see they are either 13mm or 19mm. I am after some guidance around reducing the size of the pipe to join the taps, or how this should all be approached generally. If there is a guide is love to see it.
Many thanks.
