I was wondering what I use to seal a concrete floor before laying laminate floor boards
Hi @melsky,
As you would be covering the concrete with floating floorboards, the main purpose of the sealer is to seal the surface to prevent concrete dust; it doesn't need to create any kind of aesthetic finish. Is that correct?
Realistically, you can use any concrete sealer, as long as it binds the surface, which is a concrete sealer's primary purpose. This Bastion Matte Concrete Sealer is a good, low-cost option. You could also use a seal coat of Bondcrete.
To apply these products, you would start by cleaning the surface thoroughly to remove any dirt or loose concrete dust. A wet and dry vacuum is the best tool you can use for this.
Once clean, mix your sealer based on the instructions on the packaging, then apply it using a paint roller on a pole such as this UNi-PRO 230mm Roller On A Pole With 1.55m Extendable Handi-Pole.
