Hi everyone,
I’m after some advice on rebuilding a pathway and would love guidance on the best approach.
I’d like to remove the existing pavers and replace the pathway with black concrete featuring a black exposed aggregate finish (similar to the attached photo). I also like the wet-look finish and would like to achieve something along those lines.
The existing pathway needs to be removed because:
Several pavers are broken
The path is off-centre and I’d like it re-centred
The drainage channel at the end has been tiled over, which means I can’t remove the grate to clean it
Given all of this, I’m happy to demolish the whole area and start fresh.
Dimensions
What I would like advice on:
Demolition
New Path Construction
Recommended base preparation for an exposed aggregate concrete path
Suggested slab thickness and reinforcement
Tips for achieving a black concrete with black exposed aggregate finish
Drainage Channel
Advice on installing a new drainage channel at the end of the path
Correct way to set the drain height and fall before pouring concrete
Any recommended products or common mistakes to avoid
Finish and Sealing
Thanks in advance! I’m keen to do this properly and get it right the first time. Any advice or tips would be greatly appreciated!
