Hi was wondering if there is a product to mount a fan to the beam in the attached image. Thanks in advance
Hi @LHadz86,
I was going to use this fan
as a example to achieve your outcome because it is DIY install but
the Installation says this.
I will try and find something else...
Cheers
Hello @LHadz86
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about fan mounting brackets.
I'm sorry but the store does not carry a generic fan mounting bracket that fits to patio steel roofing frames. I suggest calling the company that installed the patio frame and ask them about the possibility of installing a mounting bracket for a ceiling fan. My only other suggestion is to look into the possibility of installing a Dynabreeze 450mm Industrial Wall Fan on a post in your patio. This will save you the trouble of having to build a custom fitting on the roof.
