I removed the damaged backing from this mirror and painted the frame. How to install the mirror and the frame to a 12mm melamine sheet?
Can I use T-rex to glue the mirror, the frame and the melamine sheet together and attach the wire at the back, then use 3M Claw to hang it on a plasterboard wall?
The mirror was previously sandwiched between the frame and MDF sheet by screws. If this is better option, what screws can I use?
https://www.bunnings.com.au/3m-claw-20kg-heavyweight-hanging-solution-3ph45m-1es_p0203109?store=8057&gclsrc=aw.ds&gad_source=1&gad_campaignid=21122993677&gbraid=0AAAAADtbEB_Tcd0bZV7Iam7X2deZTyQ6P&gclid=CjwKCAjwrP3VBhBbEiwAnaqpQ4cN0d7XM-6BPSlMpZ7LwxV7sKQjr5b0pOsJOy-je1ixFq1_kLfQCxoCCFsQAvD_BwE
Thank you
