Hi all, I'm a novice DIY-er and first time using a drill to attach hardware at home, so need some advice.
I want to hang a mirror in the bathroom but won't drill into the tile wall as it's a rental and that seems harder. I can attach a bracket or hook to a cubpoard door above the sink (see pic) from which I'll be able to hang it. It's a pretty heavy old glass and wood frame mirror, so needs to be a sturdy attachment. I'm guessing if I drill into the area of the frame circled (above the sink) I'll be able to hang it close to the wall without issues - second pic to show the cupboard door frame is pretty solid.
Is it as simple as I'm assuming - (1) drill pilot holes to fit bracket, (2) screw bracket into frame with regular screws, as frame is pretty thick, (3) hang hook using a painting wire + hook. Do I need any special screws or attachments for this type of job?
Thanks in advance!
