I’ve bought a new standard 12mm quick coupling adaptor (or hose connector) and attached it to the water inlet connector. No problem.
The problem is when I turn the tap on and water gushes out from in between the two adapters/connectors.
At first I thought there was a blockage in the water inlet connector but water seeps thru when I run it under the tap (gently). It’s almost as if the mesh filter is too flimsy or something and can’t handle water pressure once I turn the tap on.
I feel like it’s the water inlet connector that’s causing problems as this is the third hose connector (12mm) I’ve tried (including the new one I bought).
In the attached photo you can see water coming out of the hose adaptor and not going through the inlet connector.
