Hi all I'm new to this group,
I have a few questions that I was hoping someone on here may be able to shed some light on re DIY aluminium frames!
At the moment I am just looking into how one would go about making aluminium frames for door (1x Front door 1x Screen door), window (various sizes that can open & secure from the inside of the van + have removable interior frames with fly screen) & a long skylight (able to pop-up/open for breeze). These are all for a caravan project (the 'Extrav-a-van' haha). I watched a very helpful video on youtube which was for a door (will post the video at the bottom), so understand the gist and will probably use the same method to a degree, except a little unsure how/what etc for seals. Anyone who can help with the following questions please jump on in! Any advice/guidance is very welcome & appreciated.. I'm flying totally blind with aluminium.
Questions:
1. Perspex: the sheets I have been looking at range between 4.5mm-12mm thickness (ideally 6mm+ for heat/cooling efficiency & sound) which I assume will work with the frame the same as glass would, but is there a thickness/size that would make life easier to better suit stock mouldings, components, seals, etc?
2. Is there a simple way to make the frames that require 2 frames (Window: perspex + fly etc) that isn't going to make a ridiculous overhang/bulky? maybe that slot's offset?
3. Cutting aluminium: What blade will do the job (just needs to last for frames any more is a bonus) that won't break the bank?
4. Seal's & water-proofing, what are my best and easiest options?
Thank you for taking the time to read,
Community manager's note: Check out How to renovate a caravan for expert advice.
https://youtu.be/mV89IYla7sc
