I am extending bathroom and replacing slab of concrete previously there with timber sub floor and in turn plywood and tiling .What size bearer and floor joists are necessary ?. The space to be covered is
1650 x 960. At the shortest point ,.i.e. 960 mm end, there is an exposed joist measuring 100mm x 50mm where there is floor boards resting on it. Will be attaching another timber to the existing joist to support plywood flooring. The joists will be running the longer length.i.e. 1650mm. How many joists do i need for a 960mm distance to the wall ?
What size joists are necessary ?
What type of timber is needed ?
What spacing is required between joists ?
Is it okay to attach the bearer to the solid brick wall with Dynabolts ?
What size bearer is required for the job ?
Which type of timber is required for the bearer ?
Is it okay to attach the joists to the bearer using saddles ?
Thanks in advance.
