Hi, we bought a frameless shower stall from Bunnings. Can that be assembled on an Estilo 900x900 shower base?
Welcome to the Bunnings Workshop community @Andy2. It's wonderful that you've joined us, and many thanks for your question about shower screen fitment.
Could you please let us know the details on the Estilo shower base and frameless shower so we can verify if they are compatible? You might like to provide the link to them from the Bunnings website.
Once we know what you are working with, we'll be able to answer your question.
Hi Mitchell,
The shower base is Estilo 900x900 I/N 4890433. The frameless shower is D’Lucci that has the shower door kit and the shower panel 600/875mm/1175mm. If they aren’t compatible can you recommend what shower base to use. Cheers,
Andy.
Hi @Andy2,
Thanks for sharing those extra details.
@MitchellMc will be back on the site on Friday, but the wonderful @EricL will be happy to help in the meantime.
Stevie
Hello @Andy2,
Welcome to the Bunnings Workshop community. It's great that you've decided to share your shower project with the community. We have a lot of members with diy experience who are more than willing to lend their knowledge.
I notice that you've mentioned the Estilo 900 x 900mm Square Shower Base and that you wish to install the D'LUCCI 10 x 2000 x 1175mm Glass Frameless Shower Panel over it. Please confirm that these are the correct items you have purchased and wish to combine together.
Please note that the Estilo 900 x 900mm Square Shower Base is designed to fit the Estilo 1830 x 830 - 900mm x 855 - 880mm Chrome Shower Screen. The D'LUCCI 10 x 2000 x 1175mm Glass Frameless Shower Panel is a wall mounted shower glass door that's designed to be placed in a fully tiled shower with no tray necessary.
You may try to put the two products together, but the 1175mm frameless shower panel is just too big for the Estilo 900 x900 base. You also mentioned a D'LUCCI 10 x 2000 x 600mm Glass Frameless Shower Panel and the 800mm version which is the other side of the shower also known as a return. These panels are too small for the Estilo 900 x 900 Shower Tray.
Perhaps it may be worth pondering the possibility of a shower, tiled from floor to ceiling with no tray and only the D'Lucci Glass Frameless shower Panel as the door with a return of 800mm.
There are certain combinations that you can do with your shower build. If you have a particular idea in mind how you would want this shower to look like, please post it here on Workshop. We will be more than happy to help you sort out the details of your shower build.
Cheers,
