I suggest using Glitz 750ml Stone And Benchtop Cleaner for removing stains from stone benches. It is specially formulated for the cleaning of granite, marble, and reconstituted stone surfaces. It’s good to look closely to see if stains are embedded into the stone or not. Acid-based cleaners often damage the finish and seal of the stone top. If they prove to be too tough and do not come off with regular cleaning, I suggest engaging the services of a professional stone polisher to clean and seal your top again. - EricL
Be careful with heat. The stone will tolerate moderately hot pans for a brief period, but prolonged direct contact or radiated heat from very hot pots can cause discolouration or damage. For Caesarstone, you might need to contact them directly if their cream cleaner hasn't worked. - Kellie
