Hi I am building an outside kitchen and I need to Know how to drill a 35mm hole in a stainless steel sink
Hi @john101,
Welcome to the Workshop community. It's great to have you with us.
Sounds like a great project! We are looking forward to seeing it come together. Hope you can share some photos with us along the way.
Let me tag some helpful members in @LePallet, @ProjectPete and @Brad to see how they might best tackle this one. Can I ask what the hole is for?
HI Jason The hole is to fit a tap
The expensive option -
https://www.bunnings.com.au/diablo-32mm-carbide-teeth-wood-and-metal-hole-saw_p0116390
https://www.bunnings.com.au/diablo-3-8-snap-lock-plus-mandrel-system_p0125917
Budget option
https://www.bunnings.com.au/craftright-3-piece-step-drill-set_p0027584
Cheap and nasty
Drill small holes around the edge of where your 32mm hole would be and break the plug out then file/grind it to size.
I have a set of holesaws that miss 32mm that will work with metal and a TCT set that has 32mm but isn't made for metal and some step drills, I would go with a step drill as they tend to be neater finish that a holesaw. I have done the drill and file method more than 23 years ago.
