How to install laundry bench and cabinets?
casey7
Hello,
I’m new here and would like an advice on how to install bench and cabinets to our Laundry- we would like the bench and cabinets to run an L shape that joins the sink. We would also like over head cupboards. Any help is much appreciated.
Re: How to install laundry bench and cabinets?
Hi Eric,
The materials you Have listed above is that what I need in order to achieve the pic u drew ?  I’ve also Changed my mind instead of the wood benchtop I would like a laminated marble benchtop...
Also the side where the washing machine is, do I need to give you the measurement, as the drawing you have drawn is that the actual size including the washing machine? U mentioned I will need 2x of those cabinets to replace the curren laundry tub I have, is that the correct size of cabinets taking the washing machine into account?
what about the above open shelves, what type are they,
are they light like an oak look ?
Also if I want to rip out the current plastic laundry cabinet where the basin is and replace with a cabinet one. Is this doable? This means I will need new basin and tap.
I hope this is not too much of a confusion, but I really hope we can achieve this plan.
thanks Casey
Hello @casey7
The cabinets I've listed should fit into your laundry space. You won't be able to use the sink from the old laundry tub. I suggest using the  Mondella Rococo Square Single Bowl Sink as your new laundry tub. You can use SpecRite 1200 x 600 x 18mm Merbau Panel for timber shelving. It's ok to use a laminated benchtop the timber benchtop I placed in your sketch was just a suggestion.
I've taken into account the size of your washing machine. There is enough space for a new cabinet once you remove your old laundry tub. Can you please tell me which is the closest store to you? I will be more than happy to make inquiries for you.
Thank you so much Eric. All sounds great.
the closes to me will be watergarden.
regards
casey
Hello @casey7
I have spoken to the In-Store Kitchen Expert Lidia. She is currently assembling your quote at the store. Unfortunately due to the current restrictions, she can only do email or over-the-phone consultations. I have given her the plans for your laundry and she is more than happy to make a quote for you. Let me reach out to you through private messaging to get some of your detials.
