Hi all, I'm looking for some advice on grouting some floor tiles.
Our main living room and walkways are covered in a 1200x200 tile running lenthways along our house and most of the grout in the main areas is chipped / broken out over time that I'm looking to clean up.
To put some context to the house, it is a 90's build that we recently purchased. The house is on a sloping plot and over the years there has been settling / subsidence to a minor extent which has lead to one side being a few cm lower then the other (due an engineers report on that in the near future).
Back to the tiles, there are a number of them that are slightly loose and due to the length of them, they rock ever so slightly along that length. I imagine they've been in the house for quite a while and the intent eventually will be to replace all of them with wooden flooring or something of that nature, though that job could be as far as 5 years away.
My questions are:
- Is there a quicker way of removing grout beyond using a grout saw. I have about 100sqm+ of grout to clean up (its all pretty old so if I do some, I should do all)
- for the areas that aren't that damaged, is it ok to just scrape the top off the grout so that when I put down new grout, the colour matches but I don't have to redo the entire depth of it, or is it safe to assume old grout is pretty loose so it'll be a mistake to do so
- I've done a test around a wobbly tile overnight and it holds firm once I've put the new grout down. Is it safe to assume this will hold or will it all come loose again in the near future. I'm really only looking to get a few years out of this job before it is all replaced.
I've attached photos below
Typical tiles throughout
Example of raised tiles
Example of chipped / missing grout
Any input would be great.
