Upcycled bedside drawers
JoeAzza
I bought this bedside drawers from a local Opportunity Shop, I have had a look at at a lot of up cycled furniture on the Bunnings Workshop and Websites, so I decided to up cycle this one, it was already in good condition, it just needed sanding, staining and painting.
I sanded the top right back to bare wood., then stained 4 coats of Cabots water based cedar, then sealed to stain with a water based satin clear coat, the rest of the unit was sanded and painted in satin black using a 100mm x 4mm nap roller, (no brush marks, I also changed the drawer knob's to brass ones.
Materials
  • 1 x Bedside drawers - used.
  • Cedar stain water based
  • Clear satin water based
  • Satin black water based
  • Wood putty for patching.
Tools
  • Sandpaper, 80, 120, 240, 400 grit.
  • 125mm  diameter sander.
  • 150mm diameter sander.
  • Paint brush and 100mm x 4mm nap roller for painting satin black.
  • Rags for staining.
  • Masking tape.
Steps
Step 1
Check unit for wear , then sand and prepare for staining and painting.
Mask off the area in between the staining area and painted area.
Paint body and drawers first (apply 3 coats light sanding in between coats).
JoeAzza_3-1690791994903.jpegJoeAzza_4-1690792012112.jpegJoeAzza_5-1690792030454.jpegJoeAzza_6-1690792047092.jpegJoeAzza_7-1690792064656.jpeg
Step 2
Once all painting is done, stain (4 coats to get the colour required)  and clear coat the top of the unit.(2 coats, light sand in between coats).
When dry install new knobs.
Job done.
Re: Upcycled Bedside drawers
Hi @JoeAzza
Thank you so much for sharing the steps you took to upcycle this bedside drawer. That black satin finish along with the cedar stain for the top looks amazing. I'm definitely going to try this on my next table project.
Tinker_Bell
Having an Impact
Re: Upcycled bedside drawers
Gorgeous project @JoeAzza! I really like the colour of the cedar stain you used for the top as it balances the black beautifully.
Katie
