@LePallet
As this project is currently being featured on the Bunnings website, could you please tell us how you went about creating the sand pit and chalkboard? If you could tell us the tools and materials you used, I'm sure Workshop community members would find it useful.
Thanks again for sharing,
Great sure @Jason
SAND PITAs the cubby was already here, I first marked out where I wanted to build the sand pit. As I didn't have much room I was happy to just go with the standard square shape.
Once I marked out the corners I concreted a timber post in each corner (50mmx50mm), then used some scrap treated pine timber I had lying around the house for the frame (around 35mmx130mm).
I then cut the treated pine 90mm posts to the sizes I wanted, had my little boy and Partner help paint them the colours we had chosen then attached them to the timber frame with long screws and glue.I screwed the posts from the inside frame, but I could recommend maybe to wrap some aluminium builders strapping around the out side of the posts to lock them tight for extra support).
Last part was to line the base with black plastic and fill with white beach wash sand.
CHALK BOARDMaking the chalk board was exciting because I've never worked with chalkboard paint.
The only materials I needed to make this was pallet wood, not structural ply wood and chalk board paint.
First I cut the Non Structural Ply to suite the size you want. I think I used 3mm ply but you can go thicker if you like.I then painted the chalkboard paint onto the plywood which I had purchased from Bunnings. Once dried i secured the board to the wall with a few screws and Sealant Adhesive mainly in the centre.Built the frame out of Recycled Pallet Wood which is the best rustic + cost efficient way to go, you can stain the timber or I would recommend just applying a clear coat of Varnish for protection.
Great stuff, many thanks for the detail @LePallet.
Other community members are welcome to join in the discussion, whether you have plans for a similar project or have already built something special.
