How to restore a deck that has seen better days?
RosemaryK
Cultivating a Following
Hello I have just painted my garden fence which I'm pretty happy with. Now my deck looks terrible in comparison!  ijust gave it a clean with White Knight to get rid of a lot of the moss. I've never painted or oiled a deck before so have no idea what I need to do. It also got a few splashes of Dulux Domino from the fence painting which I need to cover. There is also a slightly rotten patch where leaves have been sitting. What is the best thing to do with it? Thanks for your help.
Rosemary
Re: How to restore a deck that has seen better days?
Hi @RosemaryK,
You should find this guide useful: Refresh and renew your timber deck. If you have a pressure washer, that would be a good place to start. There looks to be a substantial about of moss/mildew which could be blasted off. You should also use Cabot's 1L Deck Clean and an Oates Long Handle Deck Scrub Brush to remove any contaminants on the timber. Once the timber is clean, you can thoroughly inspect it and replace any rotted boards. If the deck has deteriorated, you might also need to give it a sand.
Once you've cleaned the deck, feel free to update us with some images and we can advise whether the sanding process will be necessary before oiling. The main priority at the moment is getting the deck perfectly clean and repairing damage.
Hi @RosemaryK,
Just thought I would add that this guide by experienced Workshop member @Adam_W might be useful to you - How to renovate a timber deck.
I would also like to emphasise that a rotting deck can be very dangerous, so I also encourage you to share some photos after you have cleaned the deck so we can see any damage that needs repair.
Welcome to the community.
RosemaryK
Hi Jason and Mitchell
I think I may get a professional into do this-I think it will be too big a job on my own.
Thank you
Rosemary
RosemaryK
Hi again
After getting three quotes from $1000 to $1500, I think I want to try and do this myself. I went to Bunnings to get the Cabots Deck Clean. While I was there I chatted to a staff member who had a look at my pictures of the deck and he said it didn't look too bad and wouldn't need sanding but a good clean with a gurney. However I confessed to him that all I want is for the deck to look as good as possible with as little cost as possible as I plan to sell soon. He suggested I paint and then I wouldn't even have to clean it! I was surprised by this. I purchase the deck cleaner anyway and tried to get it a bit cleaner this morning. Now I am a bit confused about what to do- Id like it to look that lovely dark woody brown against the domino coloured fence but I really just want the biggest bang for my buck and effort so I can get on with doing something with my shoddy bathroom.   The bunnings guy thought it was water based oil that had been used previously on the deck.  What about stain? Oil ? Paint??
Thanks for your help. I really appreciate it.
Rosemary
Hi @RosemaryK,
As per my previous comments, it would be great if you could show us some images after the deck is cleaned. It's really up to you how much effort and time are put into restoring the deck. Painting the deck is a good way to cover up issues, but as @Jason mentioned, the rotted boards can be a safety issue.
Decking oils will either be natural or come with some type of stain in them. Here is the Cabot's 4L Jarrah Water Based Deck And Exterior Timber Stain. It has a stain included replicating the colour of Jarrah timber. For a dark wood colour, your best bet would be to select from the available colours in-store. However, I suspect Jarrah will be the closest match.
I'd still be of the opinion that replacing the rotted boards would be in your best interest, as any inspection of the property is likely to reveal them.
RosemaryK
Thanks Mitchell for that advice.
Here are some photos after I scrubbed with the Deck Clean and a hose. It doesn't look any different to before.  I cant easily get my hands on a gurney.
Rosemary
That is a deck that definitely needs a sanding to be fully restored @RosemaryK. The dirt and grime have fully penetrated the timber fibres, and you'd need to sand the decking back to fresh timber. Given what you mentioned above, you might want to coat the deck with an oil and stain combination, so you can move on to other projects. The darker colours will probably disguise the deterioration to a certain extent.
RosemaryK
Sorry Mitchell to clarify. Are you saying it really should be sanded but with time,money and effort being an issue I could do an oil and stain combination? Or are you saying I need to do sanding plus the oil and stain combination to be any benefit? Im really grateful for your advice here!
Rosemary
To complete a full restoration which will result in an amazing-looking deck, you need to sand first @RosemaryK. If sanding is out of the question, then I'd suggest it would be still worth applying an oil and stain. Even without sanding, it should hopefully make the deck look better than what it currently does. Unfortunately, because of the discolouration on the deck, the results you see might be less than satisfactory.
