How to stop efflorescence on concrete?
rc1
I have efflorescence occurring outside. I don’t like its look and am concerned it might over time damage the integrity of the concrete. What can I do about preventing it (ie painting etc as I’m already aware of reducing standing water) or improving its appearance?IMG_2242.jpegIMG_2241.jpeg
Re: efflorescence - what can I do?
Hi @rc1,
You could try applying a penetrative sealer over the surface to prevent moisture contact with it. I'd suggest a product similar to Crommelin 1L Natural Finish Penetrating Sealer And Water Repellent; it's designed to suppress efflorescence. You'll want to ensure that you scrub off as much of the white salts/minerals residue as possible before applying the sealer, or that look will be trapped beneath.
You'll need to coat the paving, concrete and grout lines with the sealer. Make sure it's one decent coat across the whole lot.
Can an Epoxy floor belaid over the Cromlins product
Welcome to the Bunnings Workshop community @Flip61. It's brilliant to have you join us, and many thanks for your question about applying an epoxy coating.
Epoxy coatings are designed to go directly onto a porous surface like concrete. The Crommelins product seals the surface, so you can't apply an epoxy over it. If you have a sealer on the concrete at the moment, you'd need to entirely strip it off before going through the preparation steps for the Epoxy.
Do you have an efflorescence issue but also want to use an epoxy coating in the area? If you can supply some more details about your project, I trust our helpful members will be able to assist.
There is a small amount of efflorescence coming through the slab and I;k like to seal it and put something down to make it easier to clean, it definitely needs to be a non slip surface as the last thing I want is to come home in wet weather and slide into the wall.
