Hi All,
Just thought I would post a simple automation chain for setting a schedule to dim down the Arlec globes a set times and days you require.
I work late nights on rotation and when I turn the ensuite light on I don't want to the light on full brightness waking up the better half and I don't also want to be fumbling for my phone to dim it down so I set the 2 following automations.
Someone might know how to combine them into 1 and that would be fantastic.
By setting your active period down the bottom you ate telling the automation when you want it active.
You can have the light switch flicked off and flick it on within that period and it will dim to lowest setting or whatever you have it set and it will remain in that state for that set period.
Carl
Hi @CSParnell
Is there a provision to program it on a day-to-day schedule? For example, if you're working late on Wednesday and Thursday it will run program 2 for low light, but for the rest of the week it will run program 1 for full brightness. If there is such a function you can program it for the rest of the month based on your schedule.
These are your options.
Maybe a request feature to Arlec for future release for a monthly calendar would be awesome
Hi Carl, I have recently purchased the Arlec smart 160 lights for my daughter's bedroom. I have managed to set them up but I am unable to get the full colour spectrum on the app, only about 8 colours.
Is there are to get the full spectrum?
Kind regards,
Laura
Hi @LCairns
By the looks of that dashboard they have limited the colour spectrum for that particular item, what happens when you click on the colour wheel on the right?
A typical full spectrum will look like below.
Carl
Hey @LCairns sorry I just went and had a look they are full spectrum so let me confirm you did grab these ones and then I'll check with Arlec Tech.
Welcome to the Bunnings Workshop community @LCairns. It's great to see that @CSParnell is already assisting you.
If it is the kit that @CSParnell has posted an image of, then Arlec has confirmed that it is a full-colour spectrum. They suggest that the app's layout could appear slightly different from CSParnell's. However, they've said that the colour selection bar should still be there for that product. I'm also keen to hear what happens if you hit the RGB circle. I would have thought if anything that would bring up the gradient bar.
Thanks for the quick reply!
Yes, those are the lights I purchased.
Can you please confirm for us what happens when you select the circle with the red, green and blue bars in it?
When I click on this colour (pic below) the lights just go on random colours
