When installing Siniat Furring Channel clips to Brick and render, what screws should i use?
Havinacrack
When installing Siniat Furring Channel clips to Brick/render, what screws should i use?
Keeping in mind they will be holding villaboard & on some walls tiles.
I would be spacing the battens vertical with clips every 400mm to support and battens no more than 600mm apart
Re: When installing Siniat Furring Channel clips to Brick and render, what screws should i use?
Hi @Havinacrack,
I've spent some time on your question, and I'd like to put you in touch with Siniat so they can discuss your specific needs and provide the most up-to-date and correct advice on their products. I've emailed their technical team and CC'd you in on it. They'll respond with the information you require and compatible products.
Many thanks for your patience.
