Which Mondella shower screen can I install?
Eonevans
Hi, I've installed a 3 lip mondella shower base 900x900  and tiled 2 sides. It is now ready for a screen. I was planning to put in the Mondella semi frameless 2000H 860-875DW,  but I may not have the space.
The side length, with the remaining lip is 850mm and the front is 855mm.
Does this mean I can't install the MON1145 (model number) mondella-860-875x2000mm?  Is there a way I can fit this in with modification?
I could put in the Estillo screen Estilo-900-x-1830mm-white-semi-frameless  as the measurements are smaller in depth and width, but then it is only 1830mm in height. And I have the tiling suited and prefer the 2000mm screen (bathroom ceiling is 3 metres).  Is the height of this screen exactly 1830mm, or does the bottom and top metal frames add a few more centimetres?
Thanks in advance, Ian
Re: Mondella shower screen size check for base
Hi @Eonevans,
How'd you lose the 50mm of the shower base? 850mm would be less than the required space for the Mondella semi-frameless 2000H 860-875DW shower screen.
As far as I'm aware, the 1830mm height of the Estilo unit is the overall and total height.
