Help needed, how do I attach the Ametalin 1350mm x 6.67m Thermal Liner to my tin roof or back or garage roller door? Thanks
Hi @bluesue
Please don't forget to post a photo update once the insulation is in place. I'm sure our members will be keen to see what it looks like when fully installed.
Hi does it matter if I have the white side of the reflecta insulation facing out into the room? Thanks
Hi @bluesue,
The installation instructions call for the silver side to face out into the room. Given that they've specified this, I would suggest that it is required. Often, sarking-type insulation has a specified orientation in which it performs best.
If you want to improve the appearance, you could then cover the back of the garage door with white melamine-coated MDF sheeting.
Using everything that was recommended in this how to group, thanks guys
Hi @bluesue,
Congratulations on your successful installation. You should be very proud of what you've accomplished.
It is always great to see advice turn into a finished project.
If you have any future projects, keep us in mind, we'd love to see what you come up with and offer any advice where needed.
