Hi, I've painted these MDF coasters using Resene and other acrylic paints. These will be used for hot cups or hot pots. Please advise a sealer for the craft work to make it heatproof. I have used resin in the past but it goes yellow after a while. Is there any other product or varnish that can be used ?
Hi @Sakshi,
I have to say those coasters look wonderful and I can understand why you would want to protect them as best you can.
Unfortunately, I am not aware of a clear coat that is designed specifically to resist high temperatures.
A clear coat such as White Knight 310g Clear Gloss Squirts Spray Paint can typically resist maximum temperatures of around 80°C, however, anything higher than this would likely require a specialised product.
You could also try this Bondall Gloss Monocel Clear Timber Varnish, but I'm unsure of how it would perform under intense heat.
Allow me to tag @Noyade, @Jewelleryrescue and @Dave-1 to see if they have any ideas.
Afternoon @Sakshi
Nice work
and yeah I would be trying to protect them as well.
Sad to say I really dont have an idea on what could be used to give them that long term heat proof protection 😕
Thank you, Jacob. I would try the first option that you recommended.
