I have a bed frame which is held together with 8 long bolts which engage a special nut. The nut is 9 mm diameter and 13 mm long (approximate) and has a treaded hole across the axis - from side to side of the cylindrical shape. One of these special nuts is missing. Where can I get another one?
Hello @JohnW1
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your query about the missing nut from your assembly.
I'm sorry to hear you're missing the special nut for your bed assembly. The good news is that it's available at the store and it's called the Taskmaster M8 Electro Brass Cross Connector Dowel - 4 Pack. I suggest bringing the bolt with you to make sure that it will fit the Cross Connector. However, if you need a bigger-sized Cross Connector, I recommend going to the Special Orders Desk and placing an order for the size that you need.
