Can you use dry stacking for a fence?
Wickid
I am looking to build a front fence on my property using block and aluminium slat panels.
the block work will be 600x600 pillars 8 courses high with small block wall 2 courses high between each pillar. I want to save time and money by using dry stack method and ri-bar core filling, is this an acceptable method for a non load bearing wall.
Re: Dry Stacking
Hi @Wickid,
Thank you for your question and welcome to the Bunnings Workshop community, it is great to have you with us.
I would suggest checking out the Versaloc interlocking block system from Adbri Masonry. They are manufactured with tongue and groove joints and self-locating top lugs to make installation without mortar extremely simple.
Many Bunnings stores stock the basic Versaloc blocks, but you may require some of the more specific blocks that come with their range. I'd have a look through the Versaloc Brochure to see what is available, before heading to your local Bunnings Special Orders desk to order the required components.
Wickid
Re: Dry Stacking
Thanks Jacob
I had a look and think I will go with the Versaloc blocks.
Cheers
Re: Dry Stacking
Hi @Wickid,
They are certainly a good product for the application you've described.
Keep us updated as it commences, it'd be great to see what you come up with
