How to fix loose exterior window?
Glorz
Building a Reputation
Hi all,
The bottom part of the exterior window is coming off. Looks like the adhesive that was used before I moved in is no longer working.  Any products that I can you use to fix this? Thank you
Jewelleryrescue
Re: window
Hi @Glorz
Looks like you have some old silicone  and the brown stuff liquid nails ? no matter.
Scrape the old  glue off  and  reglue  with silicoe clear it will hold the  best longest. in that situation.
Re: How to fix loose exterior window?
Hi @Glorz
Just to add to the suggestion made, I recommend using Selleys 290ml Clear Storm Waterproof Gutter And Roof Sealant. Just make sure that the surface of the aluminium is clean and free of old silicone. Please note that you'll need to use masking tape to keep the panel in place while the silicone is curing. Once it cures you can remove the tape.
Please make sure to wear personal protection such as gloves and goggles when working on your repairs.
Glorz
Thanks Eric. Took your suggestion and its all fixed now 🙂
It's great to hear that you resolved the issue @Glorz. Well done!
