How to fix loose Gainsborough door knobs?
sheila
Occasional Browser
 hi, how can I make the door knobs stay fixed on the door as unable to tighten it.
Cheers sheila
Re: how to fix loose Gainsborough door knobs
Welcome to the Bunnings Workshop community @sheila. Many thanks for your question, I'd be happy to assist.
The doorknob fixes to the door by turning the golden coloured collar flange clockwise. The thread on it matches up with the thread on the door fixing and tightens it onto the door. If it does not tighten, then there is a chance the thread is damaged and it will need to be replaced. Unless we can decipher which thread is damaged then you might need to replace the whole handle set.
Please let me know if you need further advice or had questions.
JDE
Super Contributor
@sheila
Shelia do you mean you cant get it tight or it wont stay tight ie it comes lose as you use the handle? If it is the second nail polish on the thread before you put it back may help.
JDE
