Hi, watching James Hardie videos re cladding they recommend a two part filler for filling the holes. I recently went to Bunnings but couldn't see anything of a similar type. The worker pointed me in the direction of Agnews Multi-purpose filler and Sellys Spakfilla - Heavy duty. I've used some J.Hardie Axent trim with the cladding and fixed with the screws commended; I'm concerned that these fillers might not cover the screws effectively? Can someone advise me please. Many thanks Jan.
Hi @ironbark,
I'm just reading through the James Hardie Axent installation guide and note that bullet head nails can be punched below the surface and "filled with a water-proof exterior filling compound". Agnews Multi-purpose filler and Sellys Spakfilla - Heavy duty would be suitable for this purpose. Screws must be finished flush with the board surface. I suspect this requirement is in place to prevent installers from overdriving screws into the product and compromising its integrity. An overdriven screw could cause the product to crack.
I haven't found the video you're referencing that recommends filler over screws, but if you can link me to it, I can certainly take a look. If you have already countersunk the screws, then the fillers recommended above will work to fill the holes and cover the screws.
Hi Mitchell,
thank you for that.
The video I referred to is a J. Hardie https://youtu.be/FusDQpGyYvg
The screws are/have gone into 38mm Axent trim. I countersunk the holes so that the screws are fractionally below the surface level, as I don't want the screws showing once completed.
Will the products mentioned adhere satisfactorily to the steel screw with such a small covering. That's why I was pursuing the two-part product thinking it would have more 'holding power?
Thanks Jan
Hi @ironbark,
I've contacted James Hardie technical, and they are perfectly happy with the screw being driven slightly below the surface and being filled over. You just shouldn't over-drive them halfway through the board, and it certainly sounds like you haven't done that.
They've recommended a two-part product, and Sika 1L High Strength Epoxy Repair Adhesive Concrete Fix Kit is suitable for your project. It's the next step up from something like Builder's Bog. The two-part product will have significantly more holding power than a single-part cement filler.
Remember your PPE when sanding and filling, including a dust mask and gloves.
Thank you Mitchell,
That's very helpful, much appreciated.
Cheers Jan 😊
No problems at all, Jan (@ironbark)!
Keep us updated on your project, and we'd love to see some pictures when you're done. Please feel free to reach out again if you get stuck.
Hi there,
I am also using Axon cladding inside a bathroom. I want to hide the nails.
My question is, is Agnew's multi-purpose filler sufficient to hide the nail heads, or do I have to use another filler first?
Thank you in advance for any help.
Goyko
Welcome to the Bunnings Workshop community @Goyko. It's terrific to have you join us, and many thanks for your question about filling over nail heads.
Bullet head nails can be punched below the surface and filled with a water-proof exterior filling compound such as Agnews Multi-purpose filler and Sellys Spakfilla - Heavy duty, which are sufficient. No other filler is required.
Thank you Mitchell.
That makes perfect sense.
I rang James Hardy and was told that I must use Megapoxy or similar product and then a filler. He also said that I mustn't punch the head in more than .5 mm. The whole ting made no sense to me. 2 fillers to cover a hole .5 mm deep.
I am happy to use Agnew's multi-purpose filler only.
Thank again.
Goyko
