I have a slab which mates up with the inside corner of a fence. The slab is not flat and falls toward this inside corner - so water collects there a lot. In that corner the level is probably around 2" lower than the other corner of the slab which is about 5x2 metres.
I have a DIY kit garden shed build to do, and need that area flat first as I don't want water accumulating there and finding its way into the shed.
So far I bought some yellow levelling compound from Bunnings (I cant recall what specifically) and that worked really well and has held up, but there was nowhere near enough of it.
When I went back I couldn't recall what it was so I just grabbed another filler product - which I didn;tr realise at the time but do now - was not designed for outdoor use because it has all cracked and flaked. Expensive lesson.
So what is my best option?
Can anyone name the specific product I should look for at Bunnings?
Alternatively should I just fill with standard cement? Or concrete?
I would like the EASIEST solution please because I want to get this done in the short term.
Ta.
