Due to recent flooding and using a metal crate as a coffee table, I need advice as to how to clean rust stains from vinyl flooring?
Thank you
Hello @Pjj
Welcome to the Bunnings Workshop community. It's a pleasure to have you join us, and thank you for sharing your question about your vinyl flooring.
The traditional method of removing rust stains on vinyl flooring is using Glitz 1kg Green Bi-Carb Cleaner in combination with Glitz Green 2L Cleaning Vinegar. Spread the bi-carb on the stained area and use a clean rag soaked in vinegar and vigorously wipe the area. Use a rag soaked in water to do the final cleanup.
The next step up would be to use chemical cleaners. Please test a small area first to make sure it will not damage your vinyl floor. I suggest using Diggers 2kg Rust And Stain Cleaner.
Please make sure to wear gloves and eye protection when handling chemicals.
