Hey team more questions as my project gets closer. I am currently installing floating floor over an old subfloor of tiles which are clean and flat.
My question related to transition from new floating floors down to existing carpet.
So currently there is a standard pvc Vinyl Edge Cap strip between the two as the carpet and floor are the same height. Once I put the floating floor in it will sit probably 8-10mm higher than the carpet. My question is how do I transition from the living area which will have the high floating floor, down to the carpet, without removing the old channel that is already installed and has carpet attached it it etc. I figure that I need a step down transition but have no idea what to get. I can't really remove the only transition strip channel and replace it, and worry that anything I buy wont quite work.
Any help greatly appreeciated.
bEn
