This little wooden tricycle makes an adorable pot plant holder suitable for indoors and out.
The project
I’ve made two of these. One I left bare treated pine, but this one I wanted to tart up a bit.
I made the wheels by using the two biggest hole saws I had. I made the hubs with a small one. Then I just drilled holes right through the hub and glued 6mm dowel in. When the glue had dried I cut the dowels to fit the rim and glued them to the rim with Selleys exterior PVA glue.
The planter box and frame I made with scraps. There’s a single wooden strip as a rear axle with the wheels simply screwed onto the ends. I made the handlebar and forks with other scrap stuff, running 5mm bolts through as an axle for the front wheel.
Then some painting: a Rust-Oleum primer and Rust-Oleum poppy red for the body and silver for the headlight, and a flat black water-based paint for the tyres. It only needs a bell.
It’s fairly small and is suitable for a succulent or maybe Lobelia or Osteospermum from the Bunnings nursery.
More pot plant inspiration for your home
Bunnings Workshop member Jamespeter100 used metal clothes hangers to make this ingenious pot plant ferris wheel.
Workshop member Mich1972 showed how to make an easy-care terrarium.
Workshop member MitchellM shared how you can make a recycled pallet succulent stand.
