This is the setup under my laundry sink for my washing machine in a unit. The water pipes go through a hole in the cabinet and then connect to the relevant taps. However, I told the guy who connected it that I normally only use cold water, so the hot water valve/tap is in the off position. I now want to wash some things in hot water so is it just a matter of turning the tap thing with the red dot left to turn it on.
I'm also a bit worried that the cold water tap isn't connected properly. It's just that some one said the purple tap is normally for recycled water for toilets etc. 🙄
If some one could advise that be would be great!
Under Sink Setup
