Using Smart Home Products waterproof hybrid planks, this D.I.Y. flooring installation project created a practical and attractive new lounge room floor.
The project
Here's our new lounge room hybrid plank install.
We have yellow-tongue floor on a steel frame, so we went with a plywood layer between to reduce the bounce factor (and noise). The floor is Smart Home Products Arctic Waterproof Aquaguard Hybrid Planks.
The pattern repeats, but not in the same location on the boards. We would lay a row at a time and then have to view it from all angles to ensure we didn't have an accidental match-up (some are inverted as well). We messed up one, but it will be under a radiator eventually.
As it's a new room, we didn't have to use the quad lengths to hide the gap along the edge; instead we used low-profile bullnose skirting to match the rest of the house.
Tips for installation
Google how to stagger the boards and use up the end offcuts for the start of every other row. Smart has a QR code on the front of the box that links you to this and the tricks on how to click them properly. They do pop, and you will need to run your hand over the run every now and then to check that's it's smooth.
They cut with the straight edge and a knife; we used a jigsaw for around the entrance and to cut the last board long edge side for the finish-up at the end.
We will be dropping off this transition strip at a powder coater's to be made satin black and then we will install it at the lounge room entrance.
Consider dog help an optional extra.
Tools and materials
Here are the tools and materials we used:
- Knee guards
- Sharp knife
- Spare blades
- Pencil
- Straight edge
- Masonite packers
- Rubber hammer
- Flooring
- Skirting boards
- Jigsaw.
Walls: Dulux Tranquil Retreat.
Trim: Water-based enamel satin white.
Windows: Rust-Oleum satin black.
How to install D.I.Y. flooring
For more ideas and advice check out our guides to D.I.Y. flooring, which include How to choose the right type of flooring, How to lay vinyl plank flooring and How to lay laminate flooring. And let us know if you need assistance with your own flooring project. We're here to help.
