DIY Bedroom Wainscot Panelling
We wanted to add a feature wainscot panelling wall behind the bedhead to keep it consistent with the panelling throughout the house renovation. It was a relatively easy and inexpensive DIY project and adds some character to what would otherwise have been a blank white bedroom wall.
How we did our DIY bedroom wainscoting:
- We measured the wall dimensions and sketched up a plan to work out the panel spacings. Important to get the spacings right and proportionate to the size of the room. We also measured the height of the bedhead to allow the wainscoting to still be seen with the bedhead in front of it.
- With a laser, we nailed on the bottom horizontal rail (110 x 18mm MDF Primed).
- We used liquid nails and brad nails to install a 3mm MDF sheet to act as a smooth backing for the wainscoting as opposed to using the standard plaster on the wall (can sometimes be slightly textured).
- We then lined up the laser for the top rail and used liquid nails and brad nailed the top horizontal rail on (110 x 18mm MDF Primed).
- We individually measured and cut the vertical battens (67 x 12mm MDR Primed).
- Used the vertical laser to get the alignment and nailed each vertical batten on ensuring each batten had a snug fit.
- Final bottom skirting (140 x 18mm Primed Colonial Moulding) was nailed on to tie in with all the other skirtings on the adjacent walls.
- Used a punch tool to punch in any brad nails that were sitting high and filled all the nail holes with a multipurpose filler.
- Caulked all the joints and junctions using Selleys No More Gaps Interior.
- Sanded the filler and painted using 2 coats of British Paints 4 in 1 Prep Primer Sealer Undercoat on the skirting and the wainscot panelling.
- Painted 3 coats of Dulux Wash&Wear Low Sheen (Vivid White) on the panelling and 3 coats of Dulux Wash&Wear Semi Gloss (Vivid White) on the skirting.
