What is the best and cheapest way to hide cable from alfresco electrical point to fountain (back fence of the backyard). What are my options?
I'm glad to hear you got the cable sorted @shery328.
Sing out if you need a hand with your fountain installation. We're here to help.
Thanks everyone, cable has been laid out under the artificial grass and pebbles with the help of the landscaper and electrician. Refer pics attached. My next task is to install fountain 🙂
Hey @shery328 just a follow up to see how you went with this and if you need any advice just shout out.
Hi @shery328,
We'll be keen to see those images that @CSParnell mentioned. They'll give us a much better idea of what solutions to suggest. Also, please let us know if this cable will be 12volt or 240volt. In either case, the neatest solution might be running the cable underground in Heavy Duty Rigid Conduit.
Please be advised that any 240volt electrical work needs to be installed/modified by a licensed electrician.
Ho @shery328
Thank you so much for posting.
Are you able to take some photos of the route the cable will take and the path you want the cable protected so I can visually see what might be best visually and safely suited.
Carl
Welcome to the Bunnings Workshop community @shery328. It is great to have you join us and we look forward to seeing how your backyard fountain project comes together.
Let me tag electrical experts @CSParnell and @MikeTNZ to see how they would tackle this problem. I'm sure our resident Bunnings D.I.Y. experts would also be happy to share their thoughts as soon as possible, too.
