Complete ensuite makeover for under $1200
After 9 years and three kids in our home, our ensuite was definitely looking a little worse for wear. The colours were dated, the room looked tired and overall it lacked warmth and life and just felt plain boring. The tiles, fixtures and vanity were all still in quite good condition so it was mostly aesthetic changes that needed to happen to give my ensuite a new lease on life.
With dull grey tiles, a dark brown vanity, stained grout and beige walls, some serious changes needed to happen to bring this space to life. Here’s how I made it happen:
Step 1
I started off by simply removing everything from the ensuite that wasn’t fixed down or staying. Artwork, towel rails, the mirror, the blind, baby latches and any random screws in walls were the first to go.
Step 2
I gave everything a big clean with shelly's sugar soap including walls, tiles, vanity and the glass shower screens. I also used the sugar soap on the floor tiles with a scrubbing brush to give the tiles and grout a good clean.
Step 3
Once everything was dry, I started to prep the walls for their first coat of paint. Prior to painting, I filled any holes or marks with Shellys Spakfilla and once dry gave them a light sand. I wiped over all the walls again to remove any residue from the sanding and started to tape up the edges of the walls ready to paint.
Step 4
I applied three coats of Dulux Lexicon half to the walls (except the wall I was leaving as our feature wall), allowing each coat adequate drying time in between. I also prepped the window frame, door and door frame ready to paint. I painted the door frame, door and window frame in the same colour as the walls, however used the Dulux Aquanamel Gloss for these areas.
Step 5
Once the walls, door and frames were dry, I decided to start prepping the tiles and vanity for their makeover. I opted to use the Dulux Renovation Range for the tiles and vanity area. When using this range, the most important part is making sure everything is completely clean and free from any residue, silicone or product build up. I therefore gave the vanity and tiled area another good clean with Shellys Sugar soap and removed any silicone visible around the shower frame and tiled area. I also removed the vanity doors and pulled out the draws to make these easier for painting.
Step 6
Once dry, I started off by giving the tiles and vanity one coat of the Dulux Renovation Range Primer.
Step 7
When the primer was completely dry, I proceed with painting the vanity in three coats of Dulux Renovation Range Cabinet Doors SATIN tinted to Light Rice colour. I chose to go with the Satin rather than the Gloss version for the vanity as I felt it gave a more modern and luxe look.
For the tiled area, I applied three coats of Dulux Renovation Range Tile & Benchtops GLOSS in Lexicon half (same colour as the walls for a seamless finish). I chose to go with the gloss finish for the tiled area as I didn’t want the tiles to look dry and rough, but feel after using the satin finish for the vanity, either option would have looked beautiful on the tiles.
NOTE: The most important thing to remember when applying the Dulux renovation range is each coat of paint needs a minimum of 8 hours drying time before the next coat can be applied. I did find this dragged out the completion of the project, however very thankful I followed the recommendations as the results were worth it.
Step 8
By this time, I had finally settled on a paint colour selection for the feature wall. I decided to paint the feature wall Surprise by Dulux and painted the wall with two coats.
Step 9
By the time everything was dry, I was ready to start adding some decorative pieces to the room. I reinstalled the vanity doors and used the Lane 100mm Matte Brass handles from Bunnings to replace the cabinet and draw handles. I replaced the old square mirror with the Silas Antique gold arch mirror purchased from Adairs, which is one of my favourite features in the room. I added the beautiful Luxe Resort ll artwork in the Ikea Lomviken frame to the feature wall and a hanging fern near the window in a gold hanging ring pot.
Step 10
Our original silver tapware on the vanity was damaged so this was a great opportunity to update the tap and I opted for the beautiful Brushed Brass Basin Mixer from Yabby.
Step 11
One of the very last things I did for the room was freshen up the grout on the floor tiles. I gave the tiled area another really good clean and once dry I applied two coats of the Dulux Renovation range grout pen to the grout in the entire floor area. The results were incredible and I highly recommend this pen!
Step 12
I finished off the room with a few last decorative accessories including the beautiful Brass Monstera hook from Kokonuts Living, towels from Adairs, Bamboo bath mat and Sabina soap dispenser from Target and two more indoor plants from Bunnings. I also positioned two brass hooks behind the door for hanging towels and included a cheeky Get Naked sign from Sweet Humming Bird Designs for a bit of fun!
The Budget
All in all I was thrilled with the transformation and being able to achieve such incredible results for under $1200. The most expensive part of the process was definitely the paint, but you do get what you pay for with paint and I know spending the money and time to apply the paint correctly is going to give us great long lasting results.
The breakdown
All paint, brushes, rollers and tape - $463
Brass vanity mixer tap - $225
Arch mirror - $156 (purchased on sale)
Artwork - $93 (purchased on sale)
Frame - $60
Brass hooks - $50
Grout pen - $20
Brass vanity handles (x3) - $18
Plants - $34
Towels - $37.50 (purchased on sale)
Decorative accessories (Bamboo mat, soap dispenser, candle) - $40
Total = $1,196.50
before - horrible brown vanity
