Fresh, white cabinetry gives this kitchen a clean, contemporary look.
The project
I built the kitchen carcass using an Irwin 80-tooth blade to cut clean edges as a normal blade will chip the Melamine.
The secret with Melamine is to score-cut your lines and then make the final cut. I screwed it all together with Melamine stickers to cover the screws. All the materials, including hinges and draw slides, are available at Bunnings.
The raised-panel doors are MDF. I cut them in five pieces using a frame method and using sash clamps to glue them together. The routering was done on a router table with a featherboard. You can also use a hand-held router.
The doors are painted in auto acrylic, first with etch primer and then in gloss white, followed by a clear coat.
[article footer]
More inspiration for your kitchen
Experienced Bunnings Workshop contributor Adam_W has put together this handy guide to planning a kitchen renovation. You can also check out our Top 10 most popular kitchen projects.
If you just need a quick kitchen refresh, check out our collection of 20 kitchens transformed with paint. You can begin transforming your own kitchen with our step-by-step video guides to painting kitchen cabinets and painting a tiled splashback.
Let us know if you need a hand with your kitchen project. We're here to help.
[article footer]
