Hello,
my naughty pug has scratched the external glass on my windows. Any advice to get them out or less visible would be appreciated
thank you
Welcome to the Bunnings Workshop community @Shaz2828. It's wonderful to have you join us, and many thanks for your question about restoring a glass window.
I'd recommend the Craftright 7 Piece Buffing Kit. It comes with various felt pads that can be used in a drill and a variety of cutting and polishing compounds. I suggest starting with the white polishing compound, and if you see no results, switch to the coarser brown cut & polish compound. With patience, you should be able to remove the scratches. Avoid the black compound unless necessary, as it will take some work to polish the glass back up again.
You might like to consider cutting a clear polycarbonate sheet to fit the window, which you can attach with clear double-sided tape. That way, when your naughty pug has another go at it, they'll only be scratching the sheeting.
I purchased the kit.
how do I apply the compound?thank you
Hi @Shaz2828,
Whilst the pad is spinning in the drill, place the compound block against it. The spinning motion will start cutting into the compound, which loads up the pad. It's the edge of the pad that you are applying the compound to and buffing with, not the face of the pad. Keep the steel bolt and washer well away from the glass. Your drill will be parallel or sideways to the glass whilst buffing and not in the position like you're about to drill into the glass.
Thank you for your prompt reply !
Hi Mitchell,
what is the compound to use, need to get some scratches out glass shower screen.
cheers,
Nigel
Welcome to the Bunnings Workshop community (@bul521860). It's fabulous to have you join us, and many thanks for your question about polishing compounds.The polishing compound comes in this Craftright 7 Piece Buffing Kit. I recommend starting with the white and, if you have no success, moving to the brown. You'll then need to return to the white to remove the marks from the brown polish.
You must be exceptionally careful when working around glass panels, especially shower screens. They can shatter with just a slight tap of something hard. Ensure you wear appropriate PPE, including safety glasses, a face mask, cut-resistant gloves, a long-sleeved shirt, trousers and enclosed footwear. If you are not confident in working around glass, I'd recommend you enlist the services of a professional to remove the marks for you.Please let me know if you have any questions.Mitchell
