To prep the concrete floor of garage for epoxy coating , which is better - Etching with acid or grinding the concrete ?
Wanted help to know which Epoxy primer should I use to prep the concrete floor for Epoxy coating later. My plan was to grind the floor and put a primer ( as was suggested by some you tube videos) and then put the Epoxy coat on top. Planning on getting Dymark Epoxy kit but not sure which primer to use. Some suggested Oncrete EP52 two part primer, but I can find it in Bunnings or any place near to me. Any product equivalent to Oncrete EP52 primer that I can find in Bunnings ?
Community manager's note: Check out How to apply epoxy to a garage floor for expert advice.
