Steps
Step 1
Measure your drawer's four internal walls, then determine how you want to divide your drawer. Make a rough sketch on paper.
Measure your dividing lines and your drawer's depth.
Add all measurements to get the total length and width of timber that will be required for your drawer dividers.
Step 2
Construct the longer lengths of your divider frame.
First measure the longest inside length of your drawer. Then measure your timber accordingly. Draw a straight line at the cutting point using a set square and cut your timber to length.
Step 3
Construct the shorter lengths of your divider frame.
Fasten the longer lengths of cut timber from the previous step to your drawer's sides using a clamp.
Then measure the distance between them and cut your timber length according to this size.
After cutting, place all timber lengths in the drawer to make a frame. Trim where required.
Step 4
Join all the cut pieces to assemble your divider frame.
First place the longer timber length at a right angle against the shorter length. Then drill a pilot hole through the longer length into the shorter length using a 3mm drill bit. Drill around three quarters of the way in of the length of your screw.
Apply wood glue next down the face of the shorter length. Re-position it at a right angle against the longer length and glue together.
Using a Phillips #2 drill bit, drive the 6G x 40mm wood screws into the holes. Make sure they countersink so they are flush against the pieces.
Repeat this for all other sides until your divider frame is ready. Place the frame inside the drawer and ensure it fits well.
Step 5
Build dividers to create sections in your frame. For this project, we have created seven sections in total.
To create three sections across the long section of the frame, measure the internal long length of the frame and divide it by three. These three points are where you need to fix your two timber lengths to create three sections.
Now measure the short length of your divided sections to determine the length of the remaining dividers.
Cut your timber based on those measurements. Sand the edges using a sanding block and 240-grit sandpaper.
Step 6
Join all dividers to create sections within your divider frame.
Glue and screw the cut timber pieces inside your frame as explained in Step 4. Trim where required.
Repeat the process to measure, cut and fix all the dividers until you reach your desired layout. Place the assembled drawer dividers in your drawer to ensure everything fits.
Step 7
Sand the dividers lightly, ensuring no rough edges.
Apply a coat of 4-in-1 primer to prepare the dividers for painting.
Once dry, gap the corners with the gap filler and smooth out with your finger. Wipe clean with a rag.
Now apply two coats of paint on the dividers. You can choose multiple colours for different sections.
