Wanted a bit of privacy after getting the new Pergola installed and was struggling with how to fill the 4 metre gaps between the steel posts. I saw that funksoulbro1 used steel studs and track in their Alfresco extension so I decided to also use steel as a framing solution. This is my first DIY project and absolutely loved it. I have no trade experience, just handy with a table saw, drop saw and drill. The result didn't turn out too bad.
Materials
Steel Studs and Track
Merbau Decking Boards
Lattice Makers Falling Leaves Screen Panel
Marine Plywood for backing behind screen panel
Exterior Paint for Marine Plywood backing
Decking Oil for Screens and Merbau
Zenith 8G x 12mm Metal Screws for fastening studs to track
Zenith 8G x 30 White Button Head Screws for fastening Merbau and Screen Panels to Studs
Corrugated Iron for weather protection on the external facing side of wall
The old privacy screen was a quick solution to give both sides of the fence some privacy when the Pergola first went up. It was a simple solution using Whites Screen Up posts and Merbau that would later be recycled in the final permanent screen. in the below pic you can see the first steel track in place on the horizontal rafter. As I was doing this by myself, I found the G clamp worked well as a second set of hands to hold things in place.
I decided to use white button head screws as they contrast better against the Merbau and tie in rather well with the White Pergola frame. The blue painted ply backing for the Screen Panel is also a good contrast. We were tossing up between Green, Yellow or Blue and as you can see Blue won in the end. Yet to oil the Merbau but the screens have been oiled.
The Corrugated Iron and Polycarbonate Roofing was from the old Pergola and recycled here to provide some weather protection on the external wall.
Lessons learned
Measure twice - cut once
Always wear gloves when building with steel - its sharp
Studs are easy to cut with a pair of Straight cut Aviation Snips
Table Saw with metal cutting blade is handy for cutting Corrugated Iron but not all table saws are designed to cut steel.
Make sure the frame is straight and level
And that is it, thanks for reading and I hope this gives some of you inspiration just like funksoulbro1's Alfresco extension did for me.
Regards,
Bankzee
