I built a deck that sat flush with my back door, a task made difficult with a clearance of only around 150mm from step to ground. Here is how i did it.
Materials
- 10mm Dynabolts (galvanised)
- 10mm Coach Screws (galvanised)
- 10mm Hex Bolts (galvanised)
- 100 x 100 x 105mm M10 Galvanised Angle Bracket
- 200*45 Treated Pine (doubled for frame)
- 90*45 Treated Pine (joists)
- Pryda Half Stirrups
- Pryda Nails (for Joist Hangers)
- Pryda Joist Hangers
- Macsim 8G Deck Screws + Macsim Clever Tool (highly recommend)
- 90mm Merbau
- 35-40 bags of concrete
- G-Tape and Protectadeck timber protection tapes
- Deck Spacers
Total Cost ~$4,500
Before
After
Preparation
- Removed existing porch cover and cut down tree
- Excavated an additional ~200mm of soil, giving myself ~350mm of total clearance
Drainage
- Dug trenches and installed a french drain, plumbed into an existing storm water connection (lucky)
- Geo textile fabric helps keep the slots on the Agi Pipe unclogged with dirt
- A thin layer of Scoria between Geo textile fabric and Agi Pipe also assists in keeping the dirt out
Ledger Board installed
- Sets the height of the whole deck (deduct the height of the deck boards!)
- 10mm Dynabolts were a bit overkill
- Be sure to have already marked where the joist hangers will be so that the bolts don't get in the way
Frame
- 200*45 Timber for frame. Double thickness (200*90) and joined using timber glue and Batten Screws
- Dig the holes for the posts/stirrups
- Dropped the bearers into place and screw together using Galvanised Angle Brackets
- Using three Car Jacks, carefully adjust the frame so that it's perfectly level and flush with the ledger board
- Screw the Stirrups onto the Bearers so that they 'hang' above the post holes using coach screws
- Screw the frame to the ledger board using coach screws
- Fill the Holes with concrete and leave to set (make sure the concrete has a slight dome shape to allow water run-off)
Joists
- Use string line to mark the position of the Joist Hangers
- The joist hanger nails are much cheaper than the screws. You must use the special nails/screws from Pryda
- Clamping the joist hanger onto the joist with a C-Clamp made it a bit easier
- I used 12 nails per joist hanger
Decking
- Important: Run a belt sander across uneven areas of the deck frame, smoothing them so there won't be any unevenness when walking on the deck
- If exposed to the elements, use G-Tape and Protectadeck on the frame for protection (Took approx 30 minutes with a staple gun)
- 3D printed a jig for guiding placement of deck screws
- Use Car Jacks to press warped deck boards against deck spacers (see pic)
Decking Board Installation
- Best done as 2 person job
Person 1
- Use centreline of Jig to place directly under string line
- Predrill pilot hole
- Remove Jig and use Clever Tool to drill and countersink hole
Person 2
Completion
- Carefully trim the excess off the Merbau by running a Circular Saw across either end (I used a clamped piece of timber as a guide)
