I have gone through other post around this issue. see following,
1. Tap leaks from body
2. Tap doesn't leak if washing machine connection removed entirely
3. I have washing machine with COLD water IN only.
4. I have interchanged HOT and COLD water tap. It still happen
5. Tap leaks if washing machine removed but washing machine hose attached to tap. Is this type of tap doesn't handle pressure from hose reducer at machine side? Will changing washer, o-ring and spindles help? (As stated I have interchanged hot and cold tap) Or is there hose with lesser reducer at the end? Is there a tap which can handle pressure better?
