Hi
I don't usually do DIY work and I lack the tools at home and would appreciate some tips on products and what to buy to do this project.
I need some help on how to fix this rotten door frame in the bathroom.It is next to the shower and the water has splashed on it over the years causing the bottom of the frame to bulge and soften. I have cut out the soft damp part and was wondering what products to use to fill in the void.
I have read from other posts that Earl's 250ml Wood Hardener and Builder's Bog are often recommended. Do I need to let the area dry for a few days before using the products? Which sand paper do I need to sand it down and shape it?
Do I also need to apply some wet area silicone in the gap between the floor and the door moulding to prevent water from entering the gap. Could you recommend a product for this please?
