Hello. I am attempting to make a desk.
I have purchased rubber wood bench tops, adoored table legs and vertical leg plates.
whenni went to attach the legs the 3/8 bolt from the leg was longer than the thread allowance between the leg plate and the bench top.
I thus drilled a further hole into the bench top at the appropriate depth and screwed in the legs. As a result my bench tops have now warped. Yay.
I have taken everything off and applied weight and the bench tops are now flattened some what, one is still slightly bowed.
so - do I drill further into the leg in order to reduce the depth of the 3/8 bolt and reattach the legs as before, or do I screw a mounting board of sorts (can be rubberwood offcuts) onto the edges of the desk and then screw the legs into these? This will result in me needing to trim the legs I think.
any advice would be much appreciated.
Kind regardss
